a lil vid of my van's system new vid with the new amp srry bout sound quality but this vids were taken w/ my cel and the 1st one was edited in phone too...
no...i left them as they were because the profile amp doesnt have the power to run the 2 15....but i kept playing w/ the settings and i cant hear bass on the speakers...what i did was that i decreased the bass on the HU an decreased the bass to the speakers on the external eq and there is no sound of bass in the speakers just mids and hi's
so you have 2 subs or one? if you have 2 dual 4 ohm subs then we can wire it for a 4 ohm mono load. but know this......2 of them will have to share the power. 240 watts each.
well it should be ok because when they say 480 rms is at 4 ohms but you have to wire the sub un series so it makes 8 ohms and it ill be less power that the amp is giving...anyways when the say480 its ussually at 14.4 v ...
oh okay..so its not really 480 then huh isnt it ifthe volts are around like 17 then its true wattage. so basically ur sayin i'll be safe? and do u know how wire into 8 ohms?
oh okay so i bridge a positive and negative then use the other two to hook up to the amp?? and then i can use that for a 2 ohm load on the amp???
