kool.thx ummm why do some ppl need crossovers? or does everybody so that i dont have toooo much bass coming out oh and do you think that there is a wiring problem with my h.u. or do i just need an equalizer or pre-amp or whatever
well the croosovers are ussually used with component speakers, if you buy 2 ways or 3 ways they have an internal crossover if im not mistaken. so that means you dont need the crossover, anyways amps ussually have internal crossovers. you should check if the amp's RCA's are connected right cuz your HU has an internal EQ and it has 3 pairs of RCAs 1 for the front speakers and one pair for the rear(they are probably not being used right now) and 1 pair for the sub.
wrong.you still need to have a xover on your speakers. all an eq does is boost or cut certain frequencies. a xover will keep a speaker from playing certain freqs that it cant play. like cutting sub bass from a mid range,and vice-versa
ok..i had a 7800 and it has the ability to send subbass to the rear speakers.most likely for some one without subs. so go into the menu section and see if you can change that. you can also turn the subout on/off.so check that too. it might be off
yes!if a mid tries to play bass for too long it will eventually die.same with a tweet.if its not crossed over high enough it too will fry.you also dont want a sub to try and play mid range. this is how my set up is crossed over. infinity dash plates (600hz hi pass 12db per octave.)they also have their own crossover that came with them.1 for the mid and 1 for the tweet.12db for the tweet and 6db for the mid. my door mids-(80hz hi pass )from my HU.12db per octave. since these too are coaxials they also have there own crossovers. rear 6x9's-100 hz hi pass.12 per octive sub-80hz low pass 18db per octave.
a sub should be crossed over from 80hz and lower. a good set of mids from 80 or 100 hz and higher.and tweets from around 3000-5000 hz and higher
umm...... not sure.most music these days dont have super low bass. tell me what your system cosists of and we'll see what you need and dont need.
well i have the 2 audiopipe 15' subs, 1 power acoustik amp rated at 760 rms, 1 profile baja amp rated at 480 rms, 4 kenwood 5x7 bout 50w rms, blaupunkt HU, boss equalizer and thats pretty much it
