Hey, I'm liking the idea of the Cerwin Vega Stroker and Stoker Pro Subwoofers because do it yourself recone kits are readily available. We all know how i like to burn my subs so....LOL i think this would be the best route for me. Has anyone heard these subs in person? Or know anything about Cerwin Vega, i know they have been around forever and make good high end home audio speakers. Cerwin Vega Stroker 12 12" Dual 2 ohm Voice Coil Subwoofer • Peak Power Handling: 4000 watts • Program Power Handling: 2000 watts • Sensitivity: 84 dB 1w/1m • Ellipsoid Surround • Integrated Voice Coil Heat Sinking and Modulation Ring • Extremely High-Temp Dual Coil Design • Dual Gap Motor Design • Surround Clamping Ring • Spider Clamping Ring with Integrated Speaker Terminals • Axial Edge Surround System • Field Replaceable Cone Assembly DIMENSIONS Mounting Diameter: 13.125" (333.4 mm) Mounting Depth: 8" (203.2 mm) Weight: 33 lbs. (14.97 kg) ====================================================== Cerwin Vega Stroker Pro 12 DESCRIPTION 12" Dual 2 ohm Voice Coil Subwoofer • A Reincarnation of the Legendary Stroker Woofer • Adjustable Voice Coil Bias System • Dual Differential Spider Design • Multiple Gap "Balanced Flux Motor" System • Enhanced Piston Area Surround Termination and Frame Design • Integrated Voicecoil Heatsink Assembly • Insanely High Excursion and SPL Capability • Peak Power Handling: 5000 watts • Sensitivity: 86dB 1w/1m • Frequency Response: 20-300 Hz DIMENSIONS Mounting Diameter: 13.125 " Mounting Depth: 8 " Weight: 66 lbs Cerwin-Vega Mobile
Cerwin Vega Car Audio Subwoofer Recone Kits Oh and is there other subwoofer Manufacturers that offer recone kits for their subwoofers?
never heard one nor heard anything about them so i can't really say anything about those strokers...they look beefy though
Cool!! Thanks, any more? lol It's around $800.00 for the 18" probably worth it though. Check it out, it says enclosure type - non enclosed, ? Does this mean i can use like free air design? Kicker SoloX S18X Car Subwoofer Product MPN MPN s18x 1-ohm Key Features Car Speaker Type Component Elements 1-Way Car Speaker Function Subwoofer Size 18" Nominal Power Handling 5000 Watt RMS Powered Non-Powered Technical Features Peak Power Handling 10000 Watt Frequency Response 18 Hz - 100 Hz Sensitivity 89.7 dB Impedance 2 ohm (Dual Coil) Components Woofer Material Metal Surround Material Rubber Mounting Enclosure Non-Enclosed Top Mounting Depth 11.38 In. Mounting Diameter / Length 16.69 In.
