wma or mp3?
Discussion in 'Home Audio Talk' started by a_rome, Mar 14, 2006.
  1. a_rome
    a_rome Full Member
    I have been trying to convert all the tracks I have in my computer to wma or mp3 format so I can burn my favorites. I just cant figure out how. I have Windows Media and Music Mach Juke Box. I have seen CDs with alot more tracks on them then just the 19 or 20 I can fit. Any help would be great.
  2. Streetz
    Streetz Full Member
    What file types are your music files you're trying to convert? MusicMatch can convert almost any file type. I'm guessing you're trying to convert iTunes files which are MAC file types so MusicMatch can't convert those. If that's the case I don't know if there are converts for iTunes, but search at google.
    You may have seen some CDs with 19 or 20 songs, but each CD can only hold 80 minutes (700MB). So the number of songs doesn't matter, it's the length that matters. In other words 14 songs can take up a whole CD even though you have seen some CDs with 20 songs, more then likely the CD with more tracks has more fillers. Hope this helps.
  3. Tony M
    Tony M Full Member
    Also make sure if you convert and record to cd you have a player capable of playing mp3 and or wma formats.
  4. Streetz
    Streetz Full Member
    Ignore my first post-second paragraph if what you're trying to do is convert files to MP3 and put them on a cd (not a regular music CD). If that's the case then you can fit as many MP3s on the CD up to 700MB.
    And as Tony mentioned, make sure you have something that can play MP3s.
  5. clipser-gs-t
    clipser-gs-t Full Member
    When you burn mp3, you have to change the burn type to mp3 under options.
  6. Tony M
    Tony M Full Member
    Burn type would be what format you want it recorded in.
  7. a_rome
    a_rome Full Member
    Thank you guys. I have been burning onto music CDs. And could not figure out how to get 50 or more tracks.
  8. NeverwaY
    NeverwaY Full Member
    Use Konverter and convert them all to OGG Vorbis. Otherwise:
    WMA Workshop for WMA, and CDex for MP3.
  9. JoeyGood
    JoeyGood Full Member
    or you could just burn it as a data cd and make sure all the file extensions are mp3
  10. valiants
    valiants New Member
    cool tool )))
    For conveting protected media I can advice u SoundTaxi !!!
    http://www.soundtaxi.info
    It's a great program which allows extremily fast and quality converting ;)
    All popular file formats are supported and it works just perfectly with Napster, iTunes, MSN-music, AOL-music etc... :cool: :cool: :cool:
  11. Brozly
    Brozly New Member
    I copied a lot of my cd's onto my hardrive with Nero, but saved them as mp4's, I've done some with Itunes, and Musicmatch, I liked Musicmatch the best for playback, but I use Nero for burning.
    I've got the Alpine 634 changer and 9807 reciever, I must get at least 10 albums on each cd. I'm using Windows XP64 and my burner isn't compatible through Musicmatch, so I use Nero for burning, but I don't seem to have a way to convert the mp4's back to mp3's,... guess I'll have to upload those again...
    As for the sound quality... it Is noticable, but still acceptable, expecessaly for a car.
  12. Hautewheeler
    Hautewheeler Full Member
  13. Ranger SVO
    Use Windows Media Player to rip your music.
    Go to Tools, then Options, the select Rip Music
    Under Rip Settings select MP3 from the drop down menu.
    Also adjust your file size, I would not select anything lower than 192 Kpbs
    Just above this, is the location you want your music ripped to. Select an appropriate folder
    We also need Windows Media Player to fill out all your MP3 tag information automatically. (we don't want to fill out each tag manually)
    You should still be in the options folder
    Select Library
    Where it says Automatic Media information updates for file
    Make sure Retrieve additional information from the internet is checked
    Click apply and your ready
    Now Nero is the best for making MP3 CD's
    Just make sure you select make an MP3 Disc
    One thing I do is I put songs into a folder first then name the folders, that way I can find the songs faster. Its almost like having a changer. Typically I get 6 to 7 CD's on one MP3 CD
    Have Fun
  14. vellisca
    vellisca New Member
    Soundtaxi, it's said to perform high results... :)
    I'll have to try it maybe...
  15. rover
    rover New Member
    Is it legal?
  16. vellisca
    vellisca New Member
    I hope yes. This prog converts only purchased music by legal (Napster, iTunes,...) subscribers.
