Wiring Question.
Discussion in 'Car Stereo Amplifiers' started by zenmonster, Nov 16, 2006.
  1. zenmonster
    zenmonster New Member
    I have a 01 BMW 330XI (e46).
    Which 2 wires do I use to feed the amp's (5 & 6 channel) for the sub? :confused:
    sry for the newb question. TIA
  2. DaveDSMer
    DaveDSMer Full Member
    cut the red one! BOOM! .. i mean blue.. oh well..
  3. DREAMZmustang
    DREAMZmustang Full Member
    makes no sense
  4. Willy D
    Willy D Full Member
    Need more info partner.....
    What amp? Aftermarket?? Do you have an aftermarket HU? Other speakers?
    Just what do you have in this car...need details.....
    It's kinda like saying "my car is broke....what do I do??"
    Willy
  5. DaveDSMer
    well willy from what I can tell from your post.. it seems like your 7th cylinder is misfiring so go ahead and pull the plug on it and make sure it isnt fouled up ok? If thats good we will go ahead and move on to that odd fluid thats leaking out the bottom of the block I see.
  6. Busted51
    Busted51 Full Member
    this is the most funny post i ever did see.. lol..
  7. Hautewheeler
    Hautewheeler Full Member
    yes.. more info is needed..
    Typically when we are looking to wire an amp, we would want to use a direct cable from the positive terminal of the battery to the power feed on the amp. (properly fused and insulated, of course)
    and for the ground wire, we will look for the closest quality ground to the chassis of the car.
    we don't know much about your car, and we know nothing of your amp as of yet. Please supply more information, and pictures if possible.
