Where to run wires in my Jeep?
Discussion in 'Automotive Electrical' started by chrisbean, Nov 13, 2007.
  1. chrisbean
    chrisbean Full Member
    I have a 1998 Jeep Grand and I getting ready to install a new amp but I'm having a little problem about where to run the power wire? Has anyone done a Jeep before? Is there a easyish place to run it or maybe drill a hole for it?I looked but didn't see any obvious places.
  2. danracer
    danracer Full Member
    you having problems running amp through firewall?? you could check for any rubber gaskets before you drill
  3. Mdean16
    Mdean16 Full Member
    when I did mine I drilled a hole through the passenger side of the firewall (I have the 6 cylinder so there’s plenty of room there.) From there I ran it under the carpet to the amplifier. But in retrospect I would definitely always look for a rubber grommet to use first.
  4. pedro quiroga
    yes deff look for a gromet first,if you must drill.make sure you dont drill though anything electrical,and use a gromet.
    hell even split loom and elecrical tape,till you can get a gromet.
