3500 at 2 ohms mono might be over your budget. it will have to be a huge amp to do that. maybe an american bass amp stetsom 7kd um.. a hifonics xxx 10,000 watt amp.
have you found out why so many of your amps have blown yet? cause that just has to be the worst luck ever.
lol, user error, faulty deck, faulty wiring, you name it. Well the visonik and the ma audio are within my price range.
The ma audio would be perfect actually, i have a dual 2 ohm stroker right now, so i can run that at 4 ohms until i get the second sub, then i can run them at 2 ohms MA AUDIO HK4000D 4,000 WATT RMS MONO CAR AMPLIFIER # 4,000 WATT RMS DIGITAL MONO AMP # CLASS "X" (MORE EFFICIENT THAN CLASS "D" MONO # 2000 RMS @ 4 Ohm # 4000 RMS @ 2 Ohm # 2 OHM STABLE # Temperature, Voltage & Output Level LCD Display # Thermal, Short & Overload Protection Circuitry # Platinum Plated RCA Jacks # Double Sided Epoxy PCB Board # Platinum Plated Block Terminals # Stainless Steel Finish Heat sink # Quiet, But Powerful Fan Cooled System Built-In # Full Mosfet Circuitry # Frequency Response: 10Hz - 350Hz # 24dB Low Pass Filter @ 50Hz - 350Hz # 24dB Subsonic Filter @ 15Hz - 50Hz # Variable 0 - 18dB Bass Boost Control @ 45Hz # Input Sensitivity: 0.2 - 8V # Dimensions: 12.4” Wx 2.71” Hx 25.86” D
ya, maybe i'll try and get a quote somewhere here. It was nice while it lasted lol, i'm pretty sure my old deck toasted it, it popped when it wasn't loud at all. Otherwise i'll probably go for the visonik , these 3 amps are all the same board just the visonik doesn't have the lcd screen built in the amp and is a lot cheaper. I don't need that anyways lol. Do you think there would be much difference in the parts between brands? all the same board Visonik V4000XD Clif Designs CDX-20A MA Audio HK4000D
I would probably try to fix the amp first. If it can't be fixed or it would be too expensive to fix then I'd look for another amp. You save a lot more money that way...
I might buy something new maybe this weekend, tired of this used ebay crap, never know if your gonna get rooked or not lol.
hey pedro, you know these three amplifiers have the same board, do you think there would be much difference in the parts between companies? Visonik V4000XD Clif Designs CDX-20A MA Audio HK4000D
................................... * Dynamic Power: 4000W * RMS Power (1 Ohm): 1500W x 1 * Signal to noise ratio: 80dB * Frequency Response: 20Hz to 500Hz * Low level input sensitivity: 200mV to 6VContinuously variable low-pass crossover * Base EQ control at 45Hz: 0 to 12dB * Line output with low-pass crossover * Platinum-plated connectors * Dimensions (inches): 13.8 (L) x 2.5 (H) x 8.75 (W) * signal to noise ratio: 80db * frequency response: 20hz to 500hz * continuously variable low-pass crossover * bass eq control @ 45hz: 0 to 12db * line output with low-pass crossover * platinum-plated connectors * Free remote bass knob * Crossover controls (adjustable @ 12 dB per octave * Level control * Bass boost control * subsonic filter * Line inputs * Line output * Triple fused!
i guess that answered your question. i think the power acoustik 3000d and one of soundstreams amps are the same too. and cheaper.
cool, good to know thanks, so i guess the parts can't be that much difference between models, what about that us amps amp i posted above, i might just grab that one for now. Money is a little tight as always lol.
US amps can get the job done. or this http://cgi.ebay.com/FUSION-FCA-4000...hash=item260254826141&_trksid=p3286.m14.l1318 SPL comparison http://audioforum.termpro.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=20;t=011159;p=0
