hey guys.last night i went to my buds house to help him install an amp and sub that i sold him. power acoustik LT960 4ch,and a 6in bazooka tube.dual 4 ohm.
ok..so i was going to put the eq in the dash under the a/c unit,but....we didnt have the room for the rca's.so it would have stuck out,and we didnt have a saw handy. when my bud gets a chance he w ill cut the back out to make room for it.so for now we had to wedge it under the dash and hump.
ok what do you guys think? it's nothing fancy but,he was on a budget.so i had to use a scoshe line converter.it worked great ,but i had to rig up a remote wire for the amp and eq to turn on. it is also dead quiet in there.i threw in some sq music i had and wow!way better over stock power.it could use some tweets but thats for another day.
by the way, I gotta ask. How did you do your false flooring in your car? Is that just a top cover over the amps or is boxed in?
yeah thats me.my friend is a little too big to bend like that. its boxed in... it really just a cover with braceing
Looks good. Only thing I would have done different is soldered the wires instead of using butt connectors. But its whatever works.
I searched around and that's how it's done. Just bracing with a cover. Shouldn't be too hard to do. Thanks pedro, I like the look of your set up, it's very clean. That's how i want mine to look when its finished.
thanks.i removed the tire and put it on the rack.now the sub sits where the tire was.so now you can see all the amps
