Hey i have a JVC KD-R626 that comes up with "MISWIRING CHK WIRING THEN RESET. UNIT" when ever i try to turn it on. but the problem is that the wiring is fine, see my mate has the same head unit so i tested his player in my car and it worked. and then to be sure i put my KD-R626 in his car and it still came up with the same message. The Cd player was working fine intill about a week ago when i was driving alone listening to the radio hit then i hit a bump in the road and it cut out and then started to came up with the message. I've only had this unit about 6 months. I'm not sure what to do about this is there anyway that i can get it fixed or fix it? or am i looking at a new unit? Any help would be greatly appreciated.
ok i did a little searching.. behind the faceplate there is a reset button.. get a pen and push the reset button and see if this fixes the problem... if not let me know
Hey i tried the reset button but it didn't work . I've asked around and it seems that the unit has an internal fault. So i've decided just to buy a new unit because it's probably going to be easyer and quicker then getting the other one repaired. anyway Thanks for the help.
