im upgrading
Discussion in 'Car Subwoofers' started by jmenace_thakidd, Jul 24, 2007.
  1. jmenace_thakidd
    jmenace_thakidd Full Member
    ok im gonna be punting my Punch P3 out of my trunk and going with
    an FI audio BL 15
    Fs: 35.1 Hz
    Re: 0.75 Ohms/coil
    Qms: 6.23
    Qes: .47
    Qts: .44
    Mms: 232g
    Cms: 0.089mm/N
    Sd: 810cm^2
    Vas: 81.6 l
    Spl: 90.6dB 1W/1m
    Bl: 12.8 N/A
    Xmax: 21mm
    Rms: 1000W *
    Sealed box: N/A cuft
    Ported box: 2.8-4 cuft @ 30-37Hz
    Sub OD: 15.625”
    Cut ID: 14.125”
    Mounting depth: 8.250”
    Displacement: 0.18cuft
    in theory with a custom enclosure do you guys see this sub putting up 140s
    am is prolly gonna be rockford 20001bd unless you guys can find me a 1/2 ohm stable amp tht will put out about 1200-1500 rms at 2ohms
  2. jmenace_thakidd
    sub is dual 1 ohm
    and if you guys can help with a cheaper amp that can put out
    1200-1500 rms i would appreciate it i know u can do it AZN lol
  3. aznboi3644
    how much money do you wanna spend on an amp or amps??
    This would work as a cheap but effective solution for an amp
    Power Acoustik A3000DB - 3000 watts Monoblock Power Amplifier • 2300 watts RMS x 1 chan @ 1 ohms • 1800 watts RMS x 1 chan. @ 2 ohms • 1100 watts RMS x 1 chan. @ 4 ohms • S/N Ratio: >100 dB - , Car Amplifiers, Mono Subwoofer Amps - Sonic Electronix
    Have you already bought or ordered the sub?
    What vehicle is this??
    the 140s is definitely possible...I got into the 140s with one 15 and half of the power you are gonna be using
  4. jmenace_thakidd
    im ordering it tommarow
    its going in my 02 galant
    i wanna spend about 200-350 if possible
  5. aznboi3644
    order the dual 2 ohm...finding a 1 ohm stable amp would be cheaper than finding a 2 ohm stable amp that puts out around 1200-1500 watts
    I have an Elemental Designs Nine.1
    Puts out 1200 watts at 1 ohm at 12.5 volts...puts out even more at higher voltages than that...most people have tested them to put out between 1400-1600 watts at 1 ohm
  6. electrolytic
    electrolytic Full Member
    Hey, that fs 0f 35hz looks very high to me, reminds me of my rockford fosgate sub, are you sure that sub is not for spl only?
  7. jmenace_thakidd
    well you can have it built for SPL or daily use they make them to order not a big company but has some good subs i know there BTL is for Mainly SPL though and they have a SQ sub the F.I. Q series and the the SSD is for daily use only check them out www.ficaraudio.com
  8. electrolytic
    Nice, they look like MTX subwoofers.
  9. pedro quiroga
    either one you get will be a good ass sub.
  10. jmenace_thakidd
    yea im getting the BL because it says it is right between the ALL out SQ and SPL subs a mixture of both so im hoping to put up between 130 and 140
    i finally was able to go and price some MDF at lowes today 19.99 a sheet 49X97 i think not bad seeing how i was gonna pay 250+ to have a box built im gonna build a box for my rockford and see what i can do with that before i get rid of it i gota question about the WIN Isds i have alpha and beta i put the cubic feet port tuning and port sizes in on both and come out with 2 different port lenths any comments or suggestions to what im doing wrong?
