how should i wire this
Discussion in 'Car Subwoofers' started by dbo4224, Mar 1, 2009.
  1. dbo4224
    dbo4224 New Member
    Ive got a 1800 watt 5 channel boss chaos exxtreme and 2 1000watt legacy lw1049. Ive also got 3, 325watt tweets and 2, 225watt mids, how should i wire this, ive got the amp wiring kit with the coax cord do i have to get more of those to have my amp power my tweets and mids? and series or parallel for the subs. dont be harsh just let me know whats good.
    wire 2 tweets to 2 channels and 2 mids to the other two channels and the subs on the sub channel.
    make sure the tweets will be crossed over very high. they should have a cap on them so you should be fine.
    whats the lowest load the sub ch can be wired too,and what coil configuration are the subs?
  3. dbo4224
    dbo4224 New Member
    RMS Power 120 Watts x 4 + 200 Watts x 1-Channel @ 4-Ohms Fixed High Pass Crossover(s
    RMS Power Output @ 4 Ohms : 120 Watts x 4-Channel + 200 Watts x 1-Channel
    MAX Power Output @ 2 Ohms : 300 Watts x 4-Channel + 600 Watts x 1-Channel
    Bridged Power : 600 Watts x 2-Channel + 600 Watts x 1-Channel
    thats the info from the amp
    and the subs a dual kapton voice koils
  4. pedro quiroga
    ok so im gonna guess dual 4's from the model number. 2 dual 4 ohm coils can be wired for a 1 ohm load or 4 ohms. is your amp 1 ohm stable on the sub channel?
  5. dbo4224
    dbo4224 New Member
    not quite sure it doesent say
