FS Lanzar OPTI2000D
Discussion in 'Car Audio Classifieds' started by kryptonitewhite, Feb 13, 2009.
  1. kryptonitewhite
    kryptonitewhite Full Member
    barely used, I have a single 2 ohm Fi IB3 18" and the opti loves 1 ohm and .5 ohm, 2 ohm not working for me
    $250 plus shipping.
  2. kryptonitewhite
    Car Audio > Amplifiers
    MODEL: OPTI2000D
    SERIES: OptiDrive
    MSRP: $722.19
    Optidrive 2000 Watt Half Ohm Stable Mono Block Digital Competition Class Amplifier
    SPECS
    700 Watts RMS Power @ 4 Ohms
    1100 Watts RMS Power @ 2 Ohms
    1600 Watts RMS Power @ 1.3 Ohms
    2000 Watts Max Power @ 0.5 Ohms
    4000 Watts Bridge Max Power @ 2 Ohms
    Mono Block Subwoofer Amplifier
    0.5 Ohm Stable
    MOSFET Power Supply
    PWM (Pulse-Width-Modulated) System
    Double Sided Epoxy PCB Circuit Board
    Gold Plated RCA Inputs
    Custom Terminal Block for Speaker Connections
    Thermal, Overload Short Protection
    Remote Bass Control
    Soft Turn On/Off
    THD @ 1Watt/4 Ohm: 0.1%
    S/N Ratio: 90dB
    Frequency Response: 15Hz - 150Hz (+/-3dB)
    Damping Factor @ 20Hz/4 Ohms: 400
    Low Pass Filter: 50Hz-150Hz, 24dB/Octave
    Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
    Variable Bass Boost: 0 to 18dB
    Variable Phase Control: 0 to 180
    Input Sensitivity: 200mV ~ 8V
    Input Impedance: 10k Ohm
    Line Output Impedance: 100 Ohm
    Fuse Rating: 30A x 6
    Dimensions: 10.08'' (W) x 2.12'' (H) x 19.1'' (L)
  3. jonnyv713
    can it do .5 ohm daily?
  4. daniel202010
    daniel202010 New Member
    do you think it would push 6 jbl gto1204d subs they say 300rms ea.. if so what is the best deal you can give me shipped to saucier , ms 39574 .
    i've got an autotek amx100.2 and a kicker zr360 and i would like to run just 1 amp for subs instead of 2 .
    thanks for your time
    daniel
  5. kryptonitewhite
    yes
    My buddy ran a pair of MOFO 15's small ported 45Hz tune LOUD for hours at a time
  6. kryptonitewhite
    add me on MSN Live kryptonitewhite@hotmail.com
  7. kryptonitewhite
    http://www.importtuner.com/reviews/p...er/system.html
    Quote:
    TEST RESULTS OUTPUT POWER @ 1%THD, 1KHZ, 14.4VOLTS
    MONO @ 4OHMS 770 WATTS
    MONO @ 2OHMS 1118 WATTS
    MONO @ 1OHM 1687 WATTS
    MONO @ 0.5OHM 1962 WATTS
    OUTPUT POWER @ 1%THD, 1KHZ, 12.5VOLTS
    MONO @ 4OHMS 673 WATTS
    MONO @ 2OHMS 988 WATTS
    MONO @ 1OHM 1406 WATTS
    MONO @ 0.5OHM 1635 WATTS
    DISTORTION AT RATED POWER, 1KHZ, 14.4VOLTS
    0.14% @ IMPEDANCE
    INPUT SENSITIVITY 250MV TO 8VOLTS
    FREQUENCY RESPONSE ( + 1DB) 15HZ -130KHZ
    S/N RATIO (A WEIGHTED, BELOW CLIPPING, MIN GAIN) > 83DB
    SLEW RATE 6.5V/MSEC
    DAMPING FACTOR @ 100HZ, 4 OHMS 105
    IDLE CURRENT 2.1AMPS
    MAXIMUM CURRENT CONSUMPTION,
    UNCLIPPED 117AMPS @ 1152WATTS
    EFFICIENCY AT 1/3RD POWER
    LOWEST IMPEDANCE 79%
    EFFICIENCY AT FULL POWER, 1%THD,
    LOWEST IMPEDANCE 85%
    CROSSOVER SLOPE 24DB/OCTAVE
    CROSSOVER RANGE, LOWPASS 48HZ - 155HZ
    SUBSONIC SLOPE 24DB/OCTAVE SUBSONIC RANGE,
    LOWPASS 14HZ - 56HZ
    LOW FREQUENCY BOOST +19DB @ 43HZ
    DIMENSIONS 19 1/8"L X 10"W X 2.5"H
  8. jonnyv713
    so is that the old school one then? I'm only 15 so i dont know much about Lanzar. I think i heard the old Opti's are the only ones worth buying.
  9. kryptonitewhite
    it is old, but idk if its the ones your reffering to though
    SOLD
  10. jonnyv713
    i think it is, who did you sell it to?
  11. kryptonitewhite
    97 maxima from SMD and ROE
    now i'm selling an Audio Control 6XS crossover
