Converting Power
Discussion in 'Home Audio Talk' started by jonnyv713, Feb 10, 2008.
  1. jonnyv713
    i found an adapter thing and it says output=18.75V 3.15A
  2. jonnyv713
    i just wanted to try it tonight and i have the adapter right in front of me. so will that work?
  3. electrolytic
    electrolytic Full Member
    That's too much voltage, it has to be 12 volts, the amperage is descent though lol.
  4. electrolytic
    you would probably need a multimeter too, so you know which wire is positive and which is negative, otherwise you will be frying stuff.
  5. aznboi3644
    you would fry stuff with 18 volts.
    funny thing is that those adapters aren't that accurate for the target output voltage.
    I have some 12 volt adapters that put out 15 volts.
  6. jonnyv713
    well i can just try to hook stuff up with my fried amp and find out which one is positive and which is negative cause it is already fried but when it is hooked up right it goes into protect but how do i hook it up?
  7. aznboi3644
    find out which one is power and ground with a voltmeter
  8. electrolytic
    hey jonny lol, what exactly do you want to do with this amp, it's blown and you don't have a voltmeter or multimeter to test the circuits anyways?
  9. jonnyv713
    i dont wanna do anything with it i was just gonna use it to test which was + and which was -
  10. electrolytic
    use the amp to test which is positive or negative? lol and if your wrong? Well i guess the amp is toasted anyways. But that 18volt adapter is too much anyways you need another one, or a power supply.
  11. jonnyv713
    please explain! lol what do u mean by a power supply? can u give me a link?
  12. aznboi3644
  13. electrolytic
    I use the old computer power supplies AT style not ATX, you won't get an ATX power supply to turn on because the motherboard turns it on. The old style AT power supplies have a switch that goes to the front of the computer case so it is nice to be able to turn it on and off. The proper one if you want to pump a little would be azns link i think i saw a 25 amp there but these work too for testing stuff.
    YouTube - JENSEN CAR STEREO TESTING
  14. electrolytic
  15. electrolytic
    got any burn marks on the board or transistors? lol
  16. electrolytic
    Didn't help me much, i failed at the repair.
  17. aznboi3644
    do you not have an electronics repair shop near you???
  18. electrolytic
    Who me? I'm sure there is lot's but just not sure if it's worth it. I do still have two of them Bazooka RSA150.2HC
  19. aznboi3644
    if you don't think its worth it than send those amps my way if you don't mind LOL
