I have purchased a few parts to put together an install myself and are a little stumped. Headunit is a Fusion CA-CD500 4x Fusion 220w 3way Reactor speakers 1 350w Fusion 2 channel amp 1 600w Boschmann Sub 1 P4004 Rockford 400w 4 channel amp. What im confused on is the correct wiring of these components together. The 350 will power the sub and the 4 channel for the components. Any advice will be great!
well the speakers will hook to the rockford fosgate and you'r sub will hook to the fusion 2 chnl amp now as far as hooking both the amps to the back of the head unit at the same time im not sure about (google it) srry
Yeah mate thats the plan. Thing is the Rockford has a Pass Thru connection between front input and rear input then the Fusion has another set of connections Line in L and R and Line Out L and R etc.
