blownin subs
Discussion in 'Car Subwoofers' started by xlaudio, May 12, 2006.
  1. xlaudio
    xlaudio Full Member
    I have a friend keeps blown a 10' sub
    aubiobahn subs one sub, he is using a small mono amp kicker
    he is blowing a single coil 4ohms and dual coil 2ohm
    400wats rms
    i thinks the amp is 200x1 in a four ohm and 400 x1 in a 2ohm
    thanks for your help
  2. Duct Tape
    Duct Tape Full Member
    what is it you need help with? i dont see a question in there
  3. xlaudio
    xlaudio Full Member
    why is he keep blown the speaker
  4. Duct Tape
    you said he is blowing a single 4 ohm and a dual 2 ohm? are they both in the same setup? or did he blow one after he blew the other (man that sounded bad)
    my guess though, would be that he probably has the gains and/or bass boost set too high and is distorting the hell outta of the sub. when speakers distort, they tend to blow.
  5. xlaudio
    xlaudio Full Member
    he had the single in ther first and it blow, then up'd to a dual 4ohm speaker
    the single is a 4 ohm then moved up to 2ohm set up
    the amp is a kenwood kac-81019
  6. xlaudio
    xlaudio Full Member
    i think it is kenwood kac 8101d
  7. aznboi3644
    The kenwood KAC-8101D is a very nice amp. I used to own one and they are very tough. Well these amps are underated and like duct tape was saying your friend probably just has the gain settings turned up too high.
    I had this amp hooked up to 2 15Ls at 1 ohm and it was loud as hell. Not really enough power to hit the really low notes with those subs but loud enough to set car alarms off.
    Check with ur friend and look at his settings.
  8. TheViking
    The Main reason ANY sub blows is due to clipping of the amp. Dont believe me? Hook your sub up to about 50 volt DC for about an Hour....what happened? Oh, It fried the Voice coil......
    Whenever an amp is driven into Clipping (or as many call it, distortion) It sens straight DC voltage from the power supply of the amp into the speaker. this voltage can be as high as 200 volts, even higher in some amps. Voice coils are NOT meant to see that kind of abuse.
    If the amp is working and sounding good, but always smokes subs, Its time to upgrade to more/larger subs to get what he wants...He is probably expecting to much from his little system. Might sound awesome at lower levels, but to drive it hard all the time expecting the windows to rattle in the next block is not realistic.
    I suggest a new box and subs if this is a recurring problem.
  9. ramos
    ramos Full Member
    Your on the right track. It's the extra power that ends up being turned into heat. The heat exceeds the thermal capabilities of the voice coil. and kapooey. New sub time. :)
  10. peter_euro
    peter_euro Full Member
    tell him to get a G/F to blow instead...
  11. LunarEclipse
    LunarEclipse Full Member
    audiobahn subs suck a$$ anyways unless they are the stupidly overpriced and overly powered Eternal Series....
  12. Jeffc879
    Jeffc879 Full Member
    it could be the subs
    hey i know some of you guys like audiobahn, but i dont. Audiobahn subs are made for audiobahn amps. If an audiobahn sub can handle 400rms that is 400 audiobahn amp rms e.g. 270rms. Yeah the kicker is under rated too, and extremely dirty power (some of the new kicker amps are rated at 3% thd rediculous). A combination of these 3 things is why they blow.
  13. Duct Tape
    put down the keyboard, slowly push the OFF button on your computer.
  14. ramos
    ramos Full Member
    Oh yeah :huh: all kicker amps fall under the cea rating system now ;)
  15. xlaudio
    xlaudio Full Member
    yeah found out e need to up the sub handing power. What is wrong with audiobahn?, what sub do u believe in?
  16. ramos
    ramos Full Member
    I believe in what ever sub will get the job done. The sub itself is only a small part of the picture. The enclosure design and construction can make or break even the best subwoofer. :)
  17. Hautewheeler
    Hautewheeler Full Member
    absolutely correct, ramos.. thank you.
