Big ?
Discussion in 'Car Stereo Amplifiers' started by treitrei, Jul 24, 2007.
  1. danracer
    danracer Full Member
    and is mdf strong enough to make a false floor that you can walk on it??
    depends on the thickness and if it's got plenty of bracing.
  3. danracer
    ohh so i gotta do a nice frame and then put about 3/4 MDF??
  4. aznboi3644
    I'd just keep it a common chamber
  5. pedro quiroga
    sure.if you plan on doing alot of walking on it.
    would putting the amps under the bench seats be out of the question?
  6. danracer
    well the thing is that i want the amps close to where they are now because the a/c is on the floor, on the back part. and i also want it to be really stealthy so i wanted to put the false floor on the whole back part so it looked like normal floor. because what i have now hidding the amps is a wooden box, and that is neither stealthy nor cool.
  7. danracer
    AZN this is the rear air port vel. is it good or does it need to change?
  8. pedro quiroga
    ok.gotcha.also plan on some cooling for the amps.
    if i could do it over i would have planned my floor a little diffrent.a wood bottom to avoid screwing my amps into the metal floor.
    also completly covering them with a solid cover.so i could reuse my anchor points in the hatch,but it's too late for that.
    its fine though.i have one of those rear hatch floor mats' that cover up my one amp that my box dosent cover.
    so plan it ALL out.you might have to raise the floor at least 5-6 inches (total) for good air flow and fan clearence.with about 3 1/2 to 4 inches for the amps to be in.
  9. aznboi3644
    why is your vent length 2.55 inches long...something is majorly screwed up
  10. danracer
    ok welli made the box 9.761 cuft, substracting the subs vol and that i estimated like a 9.06, the port was then putted to 37 Hz
  11. aznboi3644
    Well if you have that much room than use two 6 inch round ports
  12. danracer
    ok i changed it to 2 6 in ports and it came out 7.84 in long
  13. aznboi3644
    aight cool...what I meant about the two 4 inch ports was per sub
  14. danracer
    where shall the ports be located, on the sides??
  15. aznboi3644
    same side as the subs
  16. danracer
    ohh ok and is there any max distance for the ports to be apart from the subs?
  17. aznboi3644
    no...I would just put them in the middle between the subs
  18. danracer
    ohh ok cool
  19. danracer
    do u think that is enough support to be walked on and everything?
  20. aznboi3644
    lol you don't need that much bracing....just a few cross braces.
    3/4 inch MDF is pretty strong. Also you will have to somehow seal the MDF from moisture...if it gets wet it swells up and deforms
