Hey all. I just installed an Pioneer AVH-P3200BT in to my 06 GMC Seirra, installation went well, all connections went as per plan, no short cuts, when it first cut out, it was doing it about 3,4 min, apart, then 2, then 1, then i shut unit off. I checked my ground, and reconnected it to another metal dash support, and it did it in about 15,20 min, and never did it again....yet. I talked to a technician at a local Best Buy, and he said the Blue Chime/control box that came with the adptor harness controls the relay that causing the problen and may need to be changed, he said they have been known to go bad, and he'll will replace it at no cost, being i bought it all from them. question to you all is.........have any of you here heard, or have had this problem?
