Im looking for some ideas on a box the fit two 12's in a 77 camaro, so lets se war ya got! Thanks, Jake
Well, I put one 10-inch woofer in the same Camaro that I posted the door speaker pod. Behind the panel is a fiberglass box, shaped to fit the area, so that volume could be maximized.
Ive got my batteries mounted on each side in those spots, so was gonna mount two in the center but im very limited on space so i wanted to see some others. Thanks
maybe you can do an IB (free air) install. you would save a ton of room. but it is dependent on if the subs can work free air.
why not turn the entire trunk in to a box??? i mean with that trunk there your looking at 22" deep and wide and about 4.8' wide thats good enough to make a sub box out of???
