Amp for sale, bought it as new, only used for a month at half power. Selling on ebay for 240.00 canadian, can do better if anyones interested. 225W X 2@4Ohm, 450W X 2@2Ohms, 900W X 1@4Ohms RMS POWER
ok ithink its 1/2 ohm stereo stable and 1 ohm mono stable,but lets see what viking has to say. if its 1 ohm mono you can get a dual 2ohm kicker sub.do you still have the box your 10 came with?
200.00us shipped for the orion xtr 9002 final offer losing money now but i need to hustle and sell everything i can lol.
that amp can run prolly run .5 ohm mono for short burps if you can supply the current and not have a big voltage drop. But hell that amp will power prolly 4 kicker L7s
soooooo...Azn, my next question lol, what would you get for this for woofer or woofers. Can probably fit 3 L7s across the trunk of my taurus but it would be tight. Not sure if thats a good number to work with. Or one Super Nitro Blaster 15" in a custom box!!
what the hell is a Super Nitro Blaster 15?? Hmm...what to put in the trunk of a taurus??? how much room you wanna give up??
This is all i can find, there is very little about this amp available. This is for a hcca 2100 g4 2 x 100 @ 4 Ohm Variable Low-pass 45Hx to TBD TBD 2 x 200 @ 2 Ohm 5kHz, variable high-pass with 2 x 400 @ 1 Ohm INTELLi Q 10Hz to 10kHz, 2 x 800 @ 5 Ohm 10db of boost with INTELLi Q 1 x 400 @ 4 Ohm remote gain capable, digital 1 x 800 @ 2 Ohm display, selectable AUX out 1 x 1600 @ 1 Ohm some ideas maybe: http://www.customtunes.com/probe.html
This is what the ad said: The amp is built to military specs, 1% tolerance components, and a .02% THD. The advertised power is 1600 watts rms @ 1 ohm bridged, but it will of course deliver much more. Ones we have benched in the past produce about 1000 watts rms bridged at 2 ohms! At 1 ohm it will be well over 2000 watts if fed properly. This one benched at 1,080 watts rms @ 2 ohms bridged with a non-reactive load!
Yeah this will will do more than 1600 watts at 1 ohm...if supplied the current it demands. But i would do a couple 15s in the biggest vented box you can fit in there...i love 15's
