I was able to pick this up on Ebay for only $31.01 shipped. Only had one guy bidding on it with 5 minutes to go so I won It. It's supposed to be in perfect shape, I'm going to use it for my wifes car to power the 12" sony xplod. That should be ok for it. MTX for $31, seems like a deal to me. RMS Power (12.5 Volts DC): • 50 watts x 2 into a 4 Ohm load with less than .1% THD • 100 watts x 2 into a 2 Ohm load with less than 1% THD • 200 watts bridged into a 4 Ohm load with less than 1% THD Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC: • 85 watts x 2 into a 4 Ohm load • 140 watts x 2 into a 2 Ohm load • 280 watts bridged into a 4 Ohm load Signal to Noise Ratio: 110dB A-Weighted Damping Factor: >200 Bass Boost: Variable Centered at 40 Hz (0 to 18 dB) Crossover: 80 Hz, 18 dB Low Pass Frequency Response: 20-20,000 Hz ± .25dB Dimensions: 7" x 9" x 2" (17.8cm x 22.8cm x 5cm) Not including mounting feet 8-1/4” x 9” x 2” (20.9cm x 22.8cm x 5cm) Including mounting feet
if its the model im thinking of then you got a beast of an amp. at 14.4v it will do 3 times its rated power!!!! show me a pic
It would be nice if it did just that but it's only going to power a sony xplod. lol As long as it can do that then my wife will be happy...
ok then that is most likely the model after the one i showed you. im still sure it will over power that sony.lol those were underated back then
i know someone with two of those, ones fried but the other pounds away at two mtx5500s and does it quite well.
$30 shipped is pricey? Actually $31.01, I just saw it on egay and it had like 5 min left on the auction so I just took a chance, it seemed like a good deal.
