bought yet another car and yet again the stereo falls short... by far better then most stock stereos but it needs work... 1992 lexus sc 400 i have 1 blown tweeter and one blown mid bass driver and well the factory system how ever better then most still leaves a bit to be desired.... i have set my self at a budget of $1000 for the equiptment... yeah that works lol (focal is out of my range) subs alpine type r SWR-12D2 subwoofer amp Hifonics Brutus BRZ1200.1D thoughts from here down 4 channel amp Hifonics GLX60.4 mid bass Power Acoustik XPS-104 tweeters Rockford Fosgate PRIME R1T-S crossover Swiss Audio STX30 yeah i should probably go from 4" to 6 1/2" but i want to retain the factory holes and not have to modify or manufacture... so the fosgate tweeters are 40rms and the xps mid bass are 60w rms do i split the difference and push 100wrms to them and risk blowing the tweeters or do i push 80wrms and call it a day (yes im aware the glx60.4 pushes 120 @ 2 ohm but right now this is all thoughts...
The only issue I see is the crossover. Its a three-way. You only need a two way. I would look for a two way with a crossover point around 5000Hz. Personally, I would not even go to that much trouble. Put a 99uf capacitor on the 4-inch speaker to protect it and a 6.8uf capacitor on the tweeter. But if you insist (no problem) a two way is the way to go. The amp will not present a problem.
so um whats the difference? there both 1k wrms capable alpine swx 12 http://www.sonicelectronix.com/item_9265_Alpine-SWX-1243D.html alpine swr 12 http://www.sonicelectronix.com/item_45529_Alpine-SWS-12D4.html
