http://www.millionbuy.com/crugp16001.html would that be alright to run two 12" infinity subs? and will this one be ok? because this is alot cheaper http://www.millionbuy.com/prfap1000m.html let me know what you think
do the profile and those subs.i've had a profile 100 watt amp for 15 years still works fine.its only 320.00 total.thats a bargain
Well those subs are Dual 4 ohm so the Profile wouldnt be a good choice unless you get the 2 channel profile amp. I'd get the Crunch amp and wire it at 1 ohm...from what I've heard and read those are some tought amps and pretty good for the money
all the positives together to the + terminal and all negative terminals together to the - terminal. Basically all the positives are "parallel" to each other and same for the negatives
