alright i have Infinity Reference 6022i 6-1/2" 180W 2-way at 60 watts rms for the front and Infinity Reference 9623i 6"x9" 300W 3-way at 100 watts rms for the rear and i was gonna go with Hifonics ZXi 4406 RMS @ 4-Ohms: 4 x 55-Watts RMS @ 2-Ohms: 4 x 110-Watts RMS @ 4-Ohms: 2 x 220-Watts Crossover and Switching: Variable 12dB Octave Hi-Pass Variable 24dB Octave Low-Pass ±18dB Bass Boost at 45Hz Inputs and Diagnostics: Variable Input Level Control Power and Diagnostics LEDs DC Short Circuit Protection Over-Load Protection Connector Types: Unbalanced Inputs (RCA’s) Full-Range Line Outputs (RCA’s) and i wondering if i can jus run the rear at 2 ohms and run the front at 4 ohms 2 add some tweeters or wat should i do
alrigt but will it run at differnt ohms on diffiernt channels and i kinda wanna run tweeters will it b possiable 2 run them from the stock wiring no to the amp and will i need crossover or will the distort alot thankx
if all your speakers are 4 ohm then they will all run at 4 ohms. if you add the tweets to the front then yes,you will change the load and each front ch will run at 2 ohms,but wait to see if you need them.
no wat i was saying if i run a 4 channel wont i still have the stock wiring from the harness can i run tweeters 2 it or will it distort 2 much
ok you can but they may get enough power to keep up with the rest of the speakers. just do the four you have now.then see if you will need the tweets.
no.the tweets will not get enough power to keep up with the other speakers. your radio will only put out 10-15 watts to each tweet,and your amp will be giving the rest of your speakers around 50+ watts each.
