Some of you may know im putting a small stereo in my pit vehicle (utility cart by club car) I had planned to just start off with the head unit power. I went with an Alpine-9886 and a set of Polk Audio DB5251 5 1/4" components. Well i bought a Pyramid PB-110PX 240w amp for 120w x 2 power. On the amp it has Low input with 2 RCA plugs and High input with this harness. Do i run RCA's from my Head unit and wire up the speaker outs off my head unit to the High input harness on the amp? Either or? Both? Thanks!
ok, if your going to use the amp then its just the RCA out from the deck to the amp and then the speakers will be connected directly to the amp and not the deck. I wouldn't use the high output harness with it since you have preouts on your deck. Just use the RCA's instead.
10-4 Easy enough Thanks! Had to ask, ive only ran subs off of an amp before. never done speakers before.
