hey wats up eryone i got a 2005 dodge magnum and it came with a factory 6 disc cd changer mp3 n wma play back and xm sat which makes me dont want to change my player but i want to hook up a mid range amp and a bass amp tell me how cud i set up this on my factory disc some one please help
yup sure can!! just need a SLC, sound level converter, or speaker level converter, don't member wich it is lol. but it will wire in to some pigtails and your off!! the feed won't be the best cleanest 50-125 hz like and rca out put but it will work.
Do NOT use an LOC on your Dodge. Your Dodge uses a LAN system and correctly intergrating into the system is a must PAC Audio makes an interface that will allow you to add amplifiers. If your vehicle is equipped with a factory amplifier the you will need C2A-CRY, this will allow you to intergrate into the LAN System and give you RCA outputs. If there is no amp then an LOC may be used, but caution is advised. AOEM-CHR2 may be a better idea.
i did my buds 2006 ram quad cab and i had to use an LOC and had to rig up a switch for a remote turn on lead. he was on a tight budget,and it works well.
