What should I do?
Discussion in 'Car Subwoofers' started by SoloX531, Jul 14, 2011.
  1. SoloX531
    SoloX531 Full Member
    I just got a new amp rated at 3000 x 1 and I was wondering how I should wire my one sub for daily use. It's a 12" dual VC 4 ohm kicker L7. I'll be getting another one soon so If you could tell me how to wire dual subs too that'd be great
  2. shriver187
    shriver187 Full Member
    what amp is it?
  3. SoloX531
    Its a Powerbass ASA 1500.1DX
  4. shriver187
    well u can hook all the speaker leads up normally.. even when u get the 2nd one.. do u know anything about that amp? it is very dirty power and not very efficient...also it is rated at 1500rms x 1 @1ohm.. so with 2 of those l7's it will just be putting out 1500 watts.. maybe not even that.. with the one l7 it will put out 750watts rms.. or less..
  5. kostyam69
    kostyam69 Full Member
  6. pedro quiroga
  7. shriver187
    its actually a proven fact that most speakers are blown from being under powered.. a 1 ohm load is not bad at all.. most amps are designed just for that reason.. u need to know when ur clipping. clipping is bad.. clean power at 1 ohm is good :)
