wat should i do
Discussion in 'Subwoofer Box and Custom Fabrication' started by Adrian, Jun 4, 2008.
  1. Adrian
    Adrian Full Member
    alright fellas well i have my 2 10" L5 kickers in a single chamber box and i did the measurements and it has a total of 4.25 cuft and i want 2 port it any suggetions or wat ahould i do
  2. cccullen
    is the box you have now sealed and you want to make it a vented box?
  3. Adrian
    Adrian Full Member
    yea any way i can
  4. cccullen
    It would be better to just make a new vented box for those subs instead of trying to work with the current box that you have.
  5. aznboi3644
    It's possible to port the box you have now...weird though cuz most sealed boxes for 10's are no where near that big lol.
  6. pedro quiroga
    well i might be able to help. those 10's work well in ported boxes as small as 1.5 cf and as big as 2.25 each.
    so 4.25 ported would be just right for them. just tune them right and your in business.
  7. Adrian
    Adrian Full Member
    now thats 1 thing i need help in tunning can some 1 help
  8. pedro quiroga
  9. electrolytic
    electrolytic Full Member
    Can try this too, should make a huge difference
  10. electrolytic
  11. electrolytic
  12. electrolytic
  13. Adrian
    Adrian Full Member
    man i wish i knew wat that was but i have no clue wat hz and all that r
  14. cccullen
    The box electro has designed is 15" in height, 40" in length and 17" deep.
    It needs a 4" diameter port (round) that's 9.691" deep. The box will be tuned to 34hz.
  15. electrolytic
    Ya what he said lol, but it's two 4 inch ports-pvc pipe by 9.691 inches long. So you just need to cut two 4 inch holes in your box on the same side as the subs and put in the two pvc pipes which will tune your box to 34hz
  16. Adrian
    Adrian Full Member
    On The Box That I Have Now Thats For 2 10 Right
  17. cccullen
    I think that's where electro screwed up. I think that's for 12" L5.
    electro, is that for one or two subs? 10" or 12" L5?
  18. electrolytic
    I ran it again for two 10's it's the same results L5
  19. Adrian
    Adrian Full Member
    But I Would Have 2 Make A Whole New Box Right
  20. cccullen
    maybe you could give the measurements of your box you have right now and electro could see if he could work with it.
