these dang noises
Discussion in 'General Car Audio Discussions' started by dmo74, Feb 14, 2007.
  1. dmo74
    dmo74 Full Member
    I am running an oldschool pioneer gm amp to my door speakers. When i turn the volume up to about half way, the vocals get really quiet, and when i try to roll down the windows or lock the door, the speakers pop. This also occurs when i turn my truck off, but it is a high pitch squeak more than a pop. What's wrong here?
  2. aznboi3644
    How are all of your connections??
    power?? ground??? signal??? remote???
  3. electrolytic
    electrolytic Full Member
    probably hooked the ground from the deck onto a wire in the dash instead of to metal.:)
  4. dmo74
    dmo74 Full Member
    ground is connected directly to the frame, power is hooked up to the battery terminal. all with good secure connectors, no tape :)
  5. aznboi3644
    How is the amp grounded???
  6. dmo74
    dmo74 Full Member
    it is connected with a bolt and nut to the frame
  7. pedro quiroga
    maybe a speaker wire is pinched somewhere in the door?
  8. aznboi3644
    is the paint sanded down to bare metal??
  9. dmo74
    dmo74 Full Member
    yes all bare metal no paint
  10. TheViking
    Double check the wiring to the door speakers!!!! Pionched wires, shorted wires, grounded out wires, .............
  11. dmo74
    dmo74 Full Member
    thanks alot for the help, turns out it was a tiny splice in the speaker wire that was grounding out..
