The Plan!
Discussion in 'General Car Audio Discussions' started by Snausages01, Dec 25, 2003.
  1. Snausages01
    Snausages01 Full Member
    As most of you know I have the two 10w7s and the two Zapco C2k 6.0s for them. Well as you also know I am looking to sell the 10s, but Ive finally come up with THE PLAN!
    Here is what I am thinking:
    A Brahma 10 most likely powered by a 6.0. It will be in a small box (.2 cubes give or take a little) under the 40 side of the rear 40/60 bench seat. Under the 60 side of the seat an amp will be placed on the floor and right above it another amp will be place on the under side of the seat or on an amp rack. Also the seat will most likely be lifted to allow for the maximum space for the 10 and the amps. All of this will be hidden by some MDF covered in the stock carpet that I have from when my truck was broken into (had to replace the carpet). So when you look under the seat it will just look like a wall covered with carpet and two hole (of some shape or design) will be drilled to allow for air flow to the amps I figure putting an intake fan blowing into the intake fans of the amps and an exhasut fan placed near the exhaust fans of the amps will do the job nicely. I think overall this will look nice I may be able to modify the front baffly to make a 'hole' over the sub side to make the holes look even and centered.
    I am thinking about going this route because it seems to be the simplist thing to do. At first I was looking to do a lot of custom work with it but really Im thinking the simplier the better and the less chance of it getting stolen. I may still do the console idea but its going to take some work and I may have some time to do it and if its done right it will come out really nice.
    Also I was thinking about doing the sub up front on the transmission hump, but again doing them in the back may just be easier. I know I can get the console to look goob, but I don't think I can get it just like stock, which I would really like to.
    Thought/Opinions :unsure:
