Alright iama post out my final verdict on the system rehaul, give me some feed back, especially the comp and rear fills. Pioneer HU RearFill Front and component Subs (will be 2) 4Ch, front and rear power Big Bird for subs (thanks Johny!) so again before i submit my order lol, any thoughts on components? Mind you the subs will not be Max Power blowing off the walls, they will just be for show when some one trys to drown me out at the stoplight... :huh:
can you find a 4ch that will match your sub amp? to me it all looks like good choices. especially the head unit. very nice. i have the model just below it minus the blue tooth. you'll like it a lot.
We used to sell Kappa speakers here where I work. We quit carring them because they failed alot and the sound quality just was not there. We started carring the Infinity Reference instead. Seems to be a good speaker. Good sound quality and no failures. (we quit carring Kappas about a year and a half ago and started carring Reference)
not sure i like the amp choice...but i do like to match the sub+amp with the same company, why not go kicker?
Did you look at the PS4 series amps? These amps will match your Class D amp and make for a much cleaner looking install. Take a look at the PS4-840 of the PS4-1200 for your application. I also believe that this line has been discontinued this year and I don't know if it has a similar looking replacement Just giving you more to think about
that amp will only put out around 1200 clean watts. I don't like Solobarics...I would rather spend a little more and get a couple of these. http://www.soundsolutionsaudio.com/..._id=42&zenid=4bc00855ca80d55756e0704580b5acaa
ya i run the P6000 right now, and i love it, ive always love pioneer though. And thanks for that Azn thats good to know, i was looking at the infin references, ive never worked with speakers from them, only subs, and the subs were soso, ill check out the references though. Mm, so any suggestions on the Mono amp then? iam looking for somthing that will put out a good solid 2k watts RMS, if not a little more. as far as the subs, i was looking at those splinters, they reminded me of the Fi's we used to run, i had forgotten about them... Matching the 4ch amp, would look cleaner, Fi BL 15
