sub wiring off rear deck speakers?
Discussion in 'Car Subwoofers' started by userloser, Aug 8, 2010.
  1. userloser
    userloser Full Member
    Is there a way to wire a sub using the existing 6x9's left and right wiring in the rear deck and still maintain the 6x9's? I thought you could use the positives from both speakers.
  2. TheViking
    A sub "could" be wired to the 6x9 speakers existing wiring...sure. But to utilize both left and right positive wires is a no no.. you would want to use a Dual voice coil subwoofer, and install passive x-overs on both the 6x9's and the sub. Now what is running those 6x9's ? deck power, amp?
  3. userloser
    Just power from the deck. Panasonic 45 watts.
  4. Ranger SVO
    Off deck power, NO.
    And as far as the paasive crossover thing, forget it. More work than what its worth. And besides, deck power won't make the sub work and even with a crossover you'll fry the decks outputs trying something like that.
  5. userloser
    Right, just wanted to come off the existing wires to a seperate amp and sub
  6. TheViking
    Ranger is correct.
    if you want to use the wiring off of the rear spks to feed into an external amp,then sure no problem. been done a million times...with good results for more bottom end boom boom..
  7. userloser
    how do i not draw any of the power from the 6x9's?
  8. TheViking
    With a line level input amp or using an PL2 you will NOT take power away from your speakers..
  9. userloser
    Thanks for the great info guys!
