split
Discussion in 'Subwoofer Box and Custom Fabrication' started by Adrian, May 13, 2008.
  1. Adrian
    Adrian Full Member
    alright fellas i put my 2 10 L5 kickers in with a 1200 watt amp on my ride and man is it bumping harder than i thought but i post spme videos later well my question is wat happenns if u dont split the boxits sounds pertty good like that is there anything bad that can happen
    do you mean they share the same chamber? if they are running off of one channel then you are fine.
    if you had two diff amps running them then you can run into problems.
  3. Adrian
    Adrian Full Member
    ok so there is no posablity that i can blow a sub cuz i have herd that its easier 2 blow1 cuz sometimes i c them going differnt directions
  4. cccullen
    Different directions? how do they sound? you may have one of the subs out of phase.
    Like pedro said, if they are sharing the same chamber but running off the same amp then you shouldn't have any problems as long as your gain is set properly.
    By the way, the box that i will be building soon is one chamber.
    If you are running two different amps (one amp per sub) and sharing the same chamber you may run into problems.
  5. pedro quiroga
    make sure they are wired the same. they should both move at the same time. not one 1 way and the other the opposite way:no:
