Sony XNV-660BT
Discussion in 'Car Audio Talk Homepage News' started by Caraudiotalk, Dec 18, 2010.
    $699.00
    Bluetooth Enabled In-Dash Navigation Multimedia Command Station with 6.1" Touch-Screen, TomTom Navigation Software, and Direct 1-Wire USB Connection for iPod/Mp3
    • CD Text Display : CD/MP3/WMA/AAC data displayed
    • Illumination : White Key Illumination
    • On-Screen Clock : 12H
    • Band : AM / FM
    • Digital-to-Analog Converter : 24bit
    • Format(s) Supported : DVD, CD, CD-R / CD-RW (MP3/WMA/AAC/JPEG/MP4 files)1
    • Frequency Response : DVD / CD: 10-20,000 Hz
    • Harmonic Distortion : DVD/CD Player: 0.01%
    • Preout Impedance : 220 ohms
    • Preout Voltage : 4 volt
    • S/N Ratio : Audio Power: CEA2006 S/N 80 dBA
    • Signal-to-Noise Ratio (dB) : DVD/CD Player: 120dB
    • Station Preset(s) : 18 FM / 12 AM
    • Tone Control(s) : EQ7: 7 band EQ
    • +/- 6 dB at: 63 Hz, 160 Hz, 400 Hz, 1 kHz, 2.5 kHz, 6.3 kHz and 16 kHz.
    • Tuner Frequency Range : FM:Tuner Frequency Range(MHz): 87.5-107.9, MW:Tuner Frequency Range(kHz): 530-1710
    • Tuner Type : SSIR-EXA with RDS
    • Volume Control : Tel/Nav Attenuation Circuitry
    • Wow and Flutter : Below measurable limit
    Video Features
    • Panel Type : 6.1" TFT Active Matrix LCD Color Monitor
    • Picture Modes : Normal, Wide, Full and Zoom
    • Resolution : 800 x 480
    • Color System : PAL / NTSC / SECAM / M-PAL
    Expansion and Connectivity
    • 12V Trigger Output(s) :
    • Power antenna
    • Amplifier turn on
    • Antenna Terminal(s) : Aerial Input Terminal
    • Audio In :
    • Rear Aux in with variable level
    • Rear USB input
    • Sony Bus terminal
    • Audio/Video Input(s) : AUX1 audio/video, AUX2 audio/video and rear camera with reverse input trigger
    • Digital Audio Input(s) : -Ability to use all forms of USB devices may vary as not all devices are compatible. This unit can be connected to the following Apple products, update your device with the latest software before you use it. -iPod Nano 1st generation* -iPod Nano 2nd generation (aluminum) -iPod Nano 3rd generation (video) -iPod 5th generation (video)* -iPod Classic -iPod Touch -iPhone When you connect iPod Nano1st generation or iPod 5th generation, Passenger Control is not available. -This unit is compliant with MSC (Mass Storage Class) and MTP (Media Transfer Protocol) type USB devices compliant with the USB standard. -This unit cannot recognize USB devices via a USB hub. If you have any questions or problems concerning your unit that are not covered in this manual, consult your nearest Sony dealer.
    • Infrared Port : Wireless remote
    • RCA Audio Output(s) : Front, Rear, and Subwoofer RCA pre-amp outputs
    • Remote Jack : Optional wired remote terminal
    • USB Port(s) : Rear USB - Full Speed
