I'm getting either an Fi Q15 or Fi Q18. I can seal or port the Q15, or seal the Q18. What do you guys think I should do? My past 3 setups have been bandpass (crappy audiobahns) or ported (kicker cvr12's), I've never had sealed.
hey eazy, i have your old speakers kicker cvr12 lol, will give em a shot Q Series: Available options and what they do: Currently no options available other then Dual 1ohm or Dual 2ohm coils. But stick around we may come up with new ideas for this series to make them even better. This is currently our ‘Sound Quality’ woofer in the lineup if you are wondering. Enclosures: Q 10 – We recommend using a sealed box in the neighborhood of .2-.6 cubic feet of volume (after all displacements for those wondering). Ported box we recommend using .5-1.2 cubic feet from 28-33Hz tuning with ~15 square inches of vent. Q 12 – We recommend using a sealed box in the neighborhood of .8-1.5 cubic feet of volume (after all displacements for those wondering). (I personally think that 1.2-1.3 cubic feet is optimal imo) Ported box we recommend using 1.8-2.5 cubic feet @ 28-33Hz (I personally think that a 32hz tuning is optimal, and has the most output and is still the most musical daily driving). Use 12-16 square inches of vent area per cubic foot of volume. Q 15 – We recommend using a sealed box in the neighborhood of 2-2.6 cubic feet of volume (after all displacements for those wondering). Ported box we recommend using 2.8-4 cubic feet @ 28-33Hz. Again use 12-16 square inches of vent area per cubic foot of volume. Q 18 – We recommend using a sealed box in the neighborhood of 4-8 cubic feet of volume. Ported box we recommend using 6-10 cubic feet @ 28hz tuning, you can tune a little higher if you wish but we recommend keeping it under 32hz. Again the same 12-16 square inches of volume applies per cubic foot of volume. "borrowed from here" Something for your Reference!! Q Enclosure Recommendations - SSA:
i'd go for the 18", you weren't happy with 2 12's so might as well go big and be done with it. i'm going to pump the crap out of these kickers then get a cerwin vega stroker next year and be done with my system lol. Way too much money spent and burnt on crappy crap lol. Cheaper is not cheaper in the long run.
I'm building a 2 chamber (1.25 cubes per chamber) sealed box for the CVR12's. I'm selling the subs, amps, and box for $575-600 in the next week or two to a kid at my school. I was able to get 6 of the 7 box pieces from scrap MDF, so making the box was cheap as hell. I'll see what I think of the CVR's sealed. The only thing is, I don't know what my next car is going to be, and an 18" woofer can't fit in any car lol.
i bought this for $100.00 let me know how your sealed turns out. I got that ED 18" to fit in my car lol, but it wasn't standing perfectly straight. It will fit if you design the box with the sub facing up, that's how i'm going to build my box for the cerwin vega stroker pro, even if i get the 12", for some reason that's best bass in that position in my car.
I can put the Q18 in my trunk facing back, but in a small car I probably wouldn't be able to... I'd be forced to go sub up and I don't know how much volume I could get. I guess first I need to figure out the best sealed volume for a Q18.
Some guys on the other forum I go on said 5-6 cubes net. I can accomplish that. So now, Q15 ported vs. Q18 sealed
run it through bassbox, you have the theile parameters? specifications or did we do this already. I just got a wicked brainstorm LOL, These subs are like a dime a dozen but they are strong, the 400 watt ones, two is not enough... soooooo HAHA This would be perfect for my orion..
Doooooo it. You can get 05CVR12's for $85 shipped from techronics with a 1 year warranty. I don't have bassbox. Q18 DUAL 1 | DUAL 2 Fs: 24.5 Hz | 23.8 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 5.66 | 5.73 Qes: .64 | .63 Qts: .58 | .57 Mms: 322g | 342g Cms: 0.13mm/N | 0.13mm/N Sd: 1210cm^2 | 1210cm^2 Vas: 268 l | 268 l Spl: 89.7dB 1W/1m | 89.4dB 1W/1m Bl: 10.4 N/A | 15.1 N/A Xmax: 27mm Rms: 1000W Sealed box: 4-8 cuft Ported box: 6-10 cuft @ 28Hz Sub OD: 18.500” Cut ID: 16.750” Mounting depth: 10.000” Displacement: 0.24cuft
ok, dual 2 ohm your getting? only 1000 watts? Eazy you won't be happy, i know you're like me, you like it extremely loud, you need a sub that takes 2000 watts then you will be happy LOL and a good amp. I've had 1000 watts or more pumping into that 18" ed and it was cool but i wanted more still.
Sealed box: 4-8 cuft Ported box: 6-10 cuft @ 28Hz I was told 5-6 cubes sealed would be best. Now, I can also fit 6 cubes ported, but I doubt that's optimum. Which should I do?
Alright this ported box is going to be pretty different looking. The port is going to have to be on the outside to save volume. Here is my trunk. The main box will sit in the lower portion of the trunk in between the ledges. The spare tire will sit standing up, behind the box, more to one side. The port will hang over the ledge (in the picture I did the right side, but if the port on the driver side is better I can do that). It's kind of a strange concept, but I think that would be the easiest way to do it in my trunk.
I can't afford an upgraded alternator and a bunch of batteries... otherwise I would. I think a 1000-1100 sub amp and 400 watt mids/highs amp is about as high as I can go on a stock electrical system.
i would put the sub facin up then the ports in the sides firing into the open spaces in the trunk but idk cause i am new at the box desing stuff
Well I think the only realistic options with Fi are the Q15 ported (4 cubes @ 28-33Hz) and the Q18 sealed (5 cubes). I don't know.
sub up kicks ass in my car lol, will this fit eazy, you have a nice spot there in your trunk Each car will be different i'm sure though.
