Hey everyone, i wanted to make a box for 2 Fully Loaded Fi BTL N2 12's powered by 2 Rockford Fosgate T2500s. I have made boxes before but mostly sealed, and never for any system this powerful. I do not plan on using tubed ports. The dimensions i would like to use are 36W 15H 16.5D (Using .75" particle board) which I believe is around 4 cubic feet. What size should i make the port if I would like to have the box tuned to 32hz, which is said to be optimal for these subs. I have tried a couple box calculators but I was curious as to what others recommend. Thanks!
Yout usable volume will be less. The port will take up about 1.25 cu ft of your volume. If your port is 15-inches tall then the port will be 13.5-inches tall, 2-1/2-inches wide and it will need to be between 21 and 22-inches long. The usable volume in the box will actually be around 3.5 cu ft.
I'll help you out man! Just go to my website here and I will help you out: http://stephenaudiodesigns.webs.com/ This isn't spam, I'm just trying to help
it isn't help if you are charging to do so. the folks here help out without charging a fee. with that said, i hope you are not going to post your website in all the help threads. not trying to be an ass at all. to the OP. you may want to reconsider using partical board. mdf would be better suited if your on a budget.
sub box help Dont forget to double up the top of the box man with that much power and inches you are bound to hear or crack some wood. FI should provide port volume total most companies do you have a spec sheet? Corey
