Pioneer DEH 1900 Installation question
Discussion in 'Car Audio Head Units' started by RIGGED, Jul 21, 2007.
  1. RIGGED
    RIGGED Full Member
    Hello,
    I attempted to install this unit today and for some reason, I can't get the thing to power on. My car came without a radio so I had to identify the power and ground wires using a volt meter. To test the power, I connected another 12VDC device and it powered up just fine. I connected the ACC/red wire to the postive and the blk wire(groung) to the ground wire. Does the ground need to be attatched to the frame?
    Thanks,
    RIGGED
    did you check the fuse
  3. RIGGED
    RIGGED Full Member
    Yes-it's good.
  4. pedro quiroga
    what about the antenna.some radios wont turn on unless thats hooked up too.
  5. pedro quiroga
    what about the constant power lead.?
  6. RIGGED
    RIGGED Full Member
    I used my volt meter to determine 12vdc and ov. i even powered another device using these power leads and it worked just fine.
  7. Ranger SVO
    What kind of car is it? The pioneer Radio needs power on the yellow wire, the red wire and for now hook the ground to any chassis (metal) point in the car.
    Now if it don't turn on post back
  8. RIGGED
    RIGGED Full Member
    It's a 1993 Nissan Sentra. Do I wire the red and yellow wire together with the 12VDC?
  9. pedro quiroga
    no.the yellow is a constant power lead.for memory.
  10. RIGGED
    RIGGED Full Member
    I see. So I wire the 12vdc to the red acc wire and the black wire to the frame of the car?
  11. Ranger SVO
    And the Pioneer needs both power leads hooked up. The red wire goes to the 12-volt ACC wire and the yellow goes to a 12-volt constant source. And the black goes to chassis
    I think you've got it, just remember that both power wires need to be hooked up.
  12. RIGGED
    RIGGED Full Member
    Well, I hooked up both the yellow and the red wire to the same 12VDC power source and the radio now functions. Is there any harm in doing this? I wasn't able to find a constant 12VDC but I do get voltage from a red wire when the car is on.
    Thanks
    RIGGED
  13. pedro quiroga
    well you may not be able to store any radio stations.the yellow wire needs a constant 12 volts.
    you may be able to wire it to a constant power sorce from the fuse box,but double check behind the dash again before you go that route.
  14. RIGGED
    RIGGED Full Member
    Update
    I went ahead and exchanged the 1900 for the 2900. The good news is that the unit is up and running, the bad news-the airbag light on my car won't go off now and the clock located on my dash isn't working-oh well at least I have some decent sound in my ride now.
    Thanks for all who replied.
    RIGGED
  15. pedro quiroga
    strange........you should have that checked out.
    autozone does free diagnosticts
