opinions on these 6.5" subs
Discussion in 'Car Stereo Speakers' started by soulfly, May 9, 2011.
  1. soulfly
    soulfly Full Member
    Looking to get some midbass up front cheaply. Considering using kick panels for components and use a 6.5" sub in the stock door location.
    i can't read into specs well as far as determining how well it would work in a door location.
    i'm looking at these. i think i can make all of them fit depth wise. I can also make that door location sealed if i need to instead of IB, but whichever works best for whichever sub
    https://www.madisound.com/store/product_info.php?cPath=45_228_256&products_id=847
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-832
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-907
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=292-2590
    this one is 7", think it has 6.5" cutout dia?
    https://www.madisound.com/store/product_info.php?cPath=45_228_256&products_id=1511
  2. Ranger SVO
    Many of those woofers are 8-ohms so I would rule those out, unless you wire them parallel and then bridged to an amp.
    Also the door would need to be reinforced, a couple of layers of Dynomat (or equivalent) and maybe a 1/2-inch piece of MDF between the woofer and the door. The woofer would need to be mounted solid
    You my want to also consider the Earthquake SWS-6.5, it a really good woofer.
    Anyway, I like your idea. I'm sure it would work well
