New Truck
Discussion in 'Car Subwoofers' started by jonnyv713, Aug 28, 2007.
  1. jonnyv713
    Ok i just got a new truck. i need a really cheap system. i was thinkin i would get one or two of these Elemental Designs
    and make an enclosure for them but they have to go behind the seats where there is basically no room but i have a prefab truckbox im there and it fits. these subs need 2.0 or 2.5 cubic feet tuned to 35 hz what are the dimensions. cause i need to know if it would fit in there befor i buy them.
  2. G3n3R@1
    G3n3R@1 Full Member
    you can make up the dimensions yourself. figure out what ur maximum possible dimension is then convert that to internal dimensions(subtract .75" from each dimension assuming u use 3/4" MDF). then work the dimensions from there to match the volume that u need.
  3. jonnyv713
    so how do i match the volume
    for example on this sub would i take 2.5 cubic feet devided by 3 or what cause i aint that good at this kind of stuff
  4. G3n3R@1
    G3n3R@1 Full Member
    well u know if ur box is gonna be 1'x1'x1' then u know its 1cuft. so just adapt it, change the dimensions to say 2'x1'x1' and so forth. im tryin to explain it the best i can lol.
  5. jonnyv713
    so if i made it 6 inchesx2feetx2feet it will be 2 cubic feet
  6. aznboi3644
    Take the internal height X width X length and divide by 1728 = internal volume in cu ft
  7. jonnyv713
    ok it will be 24 inches wide by 23 inches high by 6 inches deep and the internal volume will be 4.01042 for two subs. now tuned to 35hz what should the port be
  8. aznboi3644
    Use a 6 inch round vent...firing to the side
    About 11 inches long
  9. jonnyv713
    well i dont have like any room at all in the sides and does that mean it goes in the box 11 inches?
  10. aznboi3644
    yes it goes in 11 inches...well if you can use two 4 inch round ports that are 11 inches long and have the same tuning and port area.
    have each port firing to each side
  11. jonnyv713
    there is no room on the sides at all could i just cut a vent in the front in the middle
  12. aznboi3644
    why is there no room on the sides??
    I thought it was 6 inches deep
  13. jonnyv713
    it is going in a truck behind the seats and the sides will be like half inch from the walls
  14. aznboi3644
    oic...that is a pretty narrow truck being the width of the box is 24 inches wide.
    well if you can fit the ports facing up than that would be better
  15. jonnyv713
    no my bad it is 64 inches wide sorry lol
  16. jonnyv713
    so should i just put them on the top
  17. jonnyv713
    ok i ordered the subs tonight and i changed my mind once again i am gonna put them in the jag and try to find so slim subs for the new truck when i get some more extra money
  18. jonnyv713
    if a box is bigger is that better or no
  19. pedro quiroga
    i never saw what kind of truck you got
