As some of you know, I have sold my Site code from Shop 4 sound to a new company I have had many talks with them, and they are basically doing the exact same thing I was doing. I have set up there site, and done a few tweaks for them as well I have invited the Owner, Jason, to come join our community, and offered him a Support forum much like Seth's (sandt) but they have not decided if they want one, they will allow me to add a link back to here though. In Exchange I told them I would post this message, tell you about the opening of their site Other than Bing their Web Master, I have no connection with them and can not offer customer support becuase of that But rest assured, they are good people, and there site is secure, I personally installed a 256bit Sercure Socket layer for their site Check them out http://www.xtremecarstereo.com
ohh and they will not, nor will I be spamming my site, this is the one and only "welcome" "grand opening" message
looks good mike. But there are some formatting issues that I think should be looked at. For example: go here: http://www.xtremecarstereo.com/catalog/pro...products_id=426 The info on the amp shouldnt just be crammed together like this: KX500.2 - KICKER 500W 2CH AMP W/REMOTE Power (WATTS/CHANNEL), 2 Ohm Stereo : 250 x 2 Power (WATTS/CHANNEL), 4 Ohm Bridged Mono : 500 Remote Bass Control : Yes Fan Cooling : Yes Length With Shroud (IN., CM) : 22-1/2, 57.2 Width With Shroud (IN., CM) : 10, 25.4 Height With Shroud (IN., CM) : 2-1/2, 6.35 Speaker- and preamp-level inputs Preamp outputs (pass full-range signal to another amp) High-pass/low-pass crossover (variable 50-200 Hz, 12 dB per octave) Bass boost (0-18 dB at 40 Hz) Remote gain controller with 20-foot cable Frequency response: 20-20,000 Hz Requires 4-gauge power and ground leads wiring and hardware not included with amplifier Unregulated Class A/B power supply offers a significant increase in power at 2 ohms Seperate it so I can find what Im looking for without gettin all pissed off. I have a short attention span :no: At the very least, space it out better so you can read it.
that is not part of my Design, that is the Text they entered I will tell them though.. all they need it os enter in their descriptions thanks for pointing it out I am sure it will be use full to them
