Need Help On bmw
Discussion in 'Off Topic Discussion' started by forumsnowboards, May 3, 2002.
  1. forumsnowboards
    forumsnowboards New Member
    Hi Everyone I normally use CAF but it is down and I need help. My friend has a 94 BMW 325i. The problem is where the coolant hose meets the radiator, it leeks coolant here. I took of the hose and there is a cracked plastic piece where the hose and radiator meet. Can anyone help me out as to what to do? I tried superguling the piece back on twice but it comes off.
  2. The_Ancient
    The_Ancient Full Member
    the best way is the replace the raditor
    but you could get some JB Weld or other Epoxy but make sure you get the area 100% dry and leave it off until the epoxy is COMPETELY set as per instuction for that epoxy
  3. JTz62
    JTz62 Full Member
    I second the JB Weld.
  4. sandt38
    sandt38 Full Member
    Radiator. If that neck busts off and blows a head gasket he will be pissed. Besides, if he can afford a BMW, he should be able to afford to fix it.
  5. zabooza
    zabooza Full Member
    Epoxy is great! Get the shit that has the blue and gray tubes, not sure what it is called. That is some strong shit!
