Hi there I currently have a set of 6x9's and a 12inch SVC sub running off my 4channel amp. ive also got a set of 4inch front speakers (50watt rms) which are running off the head unit. My issue is that i can hear pritty much nothing from these front speakers. what i'd like to do is connect these speakers to the same amp, i.e. run the 6x9's, sub and front speakers off the 4channel amp. Is this evan possible and if so how should i go about the wiring? and ofcorse will it solve my problem? will i get a little more sound from the front instead of all from the back? hope u guys dont mind sharing your experteese, looking forward to your responses. Thanx
Im running a digital starsound SSA-CA4 1900 watt high pass crossover (50Hz - 500Hz) low pass crossover (50Hz - 500Hz) 0dB - 12dB bass boost at 45Hz what im struggling to understand though is that ive got one channel free on the amp, how am i going to connect the four wires coming from the front speakers to one channel? thanx again for the help
I am running a digital starsound 4ch bridgeable SSA-CA4-1900watt amp High pass crossover (50Hz - 500Hz) Low pass crossover (50Hz - 500Hz) 0dB - 12dB bass boost at 45Hz What im struggling to understand tho is that my sub is currently bridged over two channels, so in a sense that means ive got one channel left on the amp, so how would i connect the four wires coming from my front speakers to this one channel? thanx again
you don't have a third ch left. if your sub is bridged then you are using 2ch's to run the sub.. leaving two for the 6x9's. what you can do is run the front speakers and the 6x9's off of the two channels in 2 ohm stereo.
yeah thats what i did, it didnt really help at all though, can still bearly hear the fronts, maybe i just need better speakers? im currently running cadence zrs45 (50watt rms)
Or a different amp. I tried to google full specs but not finding a whole lot. Are u sure you have everything wired right? I mean positives to positives negs to negs or series/parralel correct?
hi pedro. sorry for goin off topic a bit but im new to all this and have nothing but a 12" sub. what i want is to have 2 speakers in the front, 2 6x9's in the rear, and the sub. i know i will need to bridge the sub, using 2 ch's. how do i run front speakers and 6x9's off 2 channels. I really need some help on this one! cheers
Im not pedro but i see he hasnt responded yet so thought i could help...if for example you bridge ch3 and ch4 for the sub, u can then use ch1 for left front and rear, and ch2 for right front and rear....so that is 2 positive wires coming in to one positive terminal of each channel, and same for the negatives i had your exact question before and thats what i was advised to do
