my deck only has one input for the subwoofer?
Discussion in 'Car Audio Head Units' started by hss2010, Oct 13, 2011.
  1. hss2010
    hss2010 Full Member
    i have a jensen touch screen deck cd/dvd. it only has one input for the subwoofer the wire is blue if that makes any difference. How should I connect my rcas for this?
  2. subsonic
    subsonic New Member
    the wire is blue thats your single cable to tell your amps when your deck is on, if you dont have 2 rca plugs for subs then your out of luck.
  3. andy_richmond
    andy_richmond New Member
    i have the same on mine, but its a single rca, is that what you mean??? i also have the thin blue wire which is the remote for the amps. Im told mine is a mono output
  4. nsc_max
    nsc_max New Member
    If you want to add a subwoofer all you need is an rca splitter thats 1 male end & 2 female ends. This way you can use your rca cables regularly.
