$119.00 12" 400W 4-Ohm Infinite Baffle Marine Subwoofer General FeaturesPower Handling 200W RMS 400W Peak General Features Stainless steel screws resist corrosion and gold plated terminals ensure maximum signal and current transfer Silicone insulated tinsel leads for durability Weather resistant polypropylene cones Constructed using ABS plastic for durability and resistance to physical damage All feature a sealed PVC basket which prevents damaging moisture from entering the motor structure of the speaker Grilles are designed using Centrex ASA plastic which is not only impact resistant but also paintable and UV resistant General Specifications Description: 12" Subwoofer Voice Coil: 2" (5.08 cm) Mounting Depth: 5.63" (14.30 cm) Cut Out Diameter: 10.93" (27.76 cm) Wire Harness: 18" Included Environmental Spec: 500hrs ASTM B117, D4329 Volume Displacement: 26.06 cu in Frequency Response: 40Hz - 150Hz Impedance: 4Ω More...
