project i'm working on! Linear integrated circuit capacitors having greater capacitance per unit area by using lateral flux. One embodiment comprises a two metal layer capacitor wherein each metal layer is comprised of two capacitor conductive components. The capacitor conductive components are cross-coupled so that the total capacitance is the sum of the vertical flux between the metal layers, and the lateral flux along the edges between the two capacitor conductive components in each of the metal layers. The lateral flux between the capacitor conductive components in a single metal layer increases the capacitance per unit area and decreases the bottom-plate parasitic capacitance. Increasing the length of the common edge formed by capacitor conductive components in a metal layer increases the capacitance per unit area. In one lateral flux capacitor, each metal layer is comprised of a plurality of rows, alternate rows are coupled together such that lateral flux is generated between each of the rows. The rows are also cross-coupled with rows in adjacent metal layers to provide vertical flux. Fractal shapes can be used to maximize the length of the perimeter of adjacent capacitor conductive components in a single metal layer. The Koch Islands and Minkowski Sausage families of fractals are particularly well suited for generating capacitor conductive component perimeter shapes. These fractals are generated by selecting an initiator shape and repeatedly applying a generator. The fractal shapes are generated by a computer program based upon user input parameters.
Some of the most efficient dielctric compoinds that can be use in a capacitor of this type are those of non risidual nature. The EMP of the inrush current has a dramatic effect upon the flux density. The lower the electrical co efficient, the higher the rateing of the capacitor. In real world terms, this means that the higher the resistance, the lower the the residual magnetism in a feild dictated by capacitance, yet at the same time inductance propeties are exhibited in a micro flambuyant wave at a frequency that tis derived from the square of the resonace divided by the amount of voltage applied. The best insulators include jello brand pudding, in chocolate flavor, silly putty after it has been imprinted with at least 200 cartoon pictures, the used oil out of 1943 john deeres seems to have the highest effect in absorbing the residual polarization effects. This is due primarily to the type of castings in the engine itself. The core elemnts in the engine block are derived from Peru, which has a magnetic ley line running through it. this in turn effects the oil, which in turn effects the cap n a most non- unlinear way. The only other insulator is that of a uncircumscied virgin of the female race of the iranian race who exhibits both male and female charactoristics, other wise known as a she-male....Though putting a live person in a cap of this nature tends to reduce the life expectancy of said subjuct to nill....... I find that this kind of capacitance is best put into a realm of occulinear stages, which in effect makes it limited in its delivery of current. The very idea is presumed to deliver a current that exceeds even the largest of conductors we have in stock, even at supercooled temps.... For the average user, i suggest a ground to the gas cap gasket of said vehicle and a positive connection to the right side power window motor.... with about 3K ohms of resistance in a non inductive sandstone resistor encased in a aluminim heat sink with a constant 30 degree of water cooling.
http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=%2Fnetahtml%2FPTO%2Fsrchnum.htm&r=1&f=G&l=50&s1=6,084,285.PN.&OS=PN/6,084,285&RS=PN/6,084,285 You got it viking but ectoplasm is used as the insulator not pudding!
Ectoplasm, in cytology, is the outer part of a cell's cytoplasm. Still in biology, ectoplasm can refer to the outer bodily regions of the jelly fish. Ectoplasm (parapsychology): A substance or spiritual energy "exteriorized" by physical mediums. Ectoplasm is also a term used to describe the vapour appearing on the wings of an aircraft when it is performing high-energy manoeuvres. Typically this effect is seen by most people at airshows during modern jet fighter aerobatic displays. See also St. Elmo's Fire. This effect also has other names in other parts of the world. Ectoplasm - A cocktail made with vodka. Ectoplasm - A BBC7 radio play. http://en.wikipedia.org/wiki/Ectoplasm
Meissner effect How about freezing it so there is zero resistance. Superconductivity http://en.wikipedia.org/wiki/Superconductors
A magnet levitating above a high-temperature superconductor, cooled with liquid nitrogen. Electrical current flows near the surface of the superconductor, acting to exclude the magnetic field of the magnet (the Meissner effect). This current, which lasts indefinitely, effectively forms an electromagnet that repels the magnet.
if it were'nt for my many years watching startrek i would not have understood any of that!:huh: :lol:
