Kicker 10ZX350.4
Discussion in 'Car Audio Talk Homepage News' started by Caraudiotalk, Feb 9, 2010.
    <img border=0 src=http://www.onlinecarstereo.com/CarAudio/assets/ProductImages/Kicker_10ZX3504.jpg />
    $209.00
    350W RMS A/B Class ZX Series 4-Channel Car System Amplifier (ZX350.4)
    • Balanced differential inputs for noise elimination and factory-radio compatibility
    • 3 automatic turn-on modes
    • +18dB of boost centered at 40 hertz
    • Optional end caps available
    • Optional vinyl skins for personalizing heat sinks available
    • KICKER Amp’s actual power always exceeds its rated power, documented inside each carton
    General Specifications
    • Frequency Response: 20Hz-20kH, +0/-1dB
    • Input Sensitivity: High Level 250mV-10V, Low Level 125mV-5V
    • Signal-to-Noise Ratio: >95dB, a-weighted, re: rated power
    • Active Crossover: 12dB/octave, variable 50Hz-200Hz, selectable high pass, low pass, or all pass
    • KICKEQ Boost: Variable to +18dB, centered @ 40Hz
    • Height: 2-1/8", Width: 9-5/8", Length: 13-1/2"
