How Do You Check Your Modem Speed?
Discussion in 'Off Topic Discussion' started by Civic96, Feb 19, 2004.
  1. Civic96
    Civic96 Full Member
    I just went from Comcast Cable to Verizon DSL and I I want to know what my DL and UL speeds are....where can I check?
  2. ASM
    ASM Full Member
  3. Civic96
    Civic96 Full Member
    DSL is slowe than cable right? :(
    It seems like my cable DLed much faster.....
  4. ASM
    ASM Full Member
    It really depends on the service. Both have the capability to be really fast.
    In general I would say DSL is a little slower.
    DSL speeds can also depend on your distance from the provider.
  5. The_Ancient
    The_Ancient Full Member
    DSL is inherantly Slow due to the Fact the DSL have lower Caps in place
    the Common Res. Line for DLS is 768kb/s where most cable are "uncapped" d/l putting them at about 1mbit or higher
    the best way to get your speed is to do to www.testmyspeed.com and select a Test Center closest to your House
    this will elminate "network traffic" which can through off your test and make it slower than it really is, which is no fault of your ISP's but that of other Networks your tring to get through when testing
  6. geolemon
    geolemon Full Member
    Not bad for dialup...
    I scored a 43K.
  7. Honest Bob
    Honest Bob Full Member
    What Mike said! Cable is shared bandwidth. DSL is not shared. With the DSL you will probably get a more consistant connection.
  8. The_Ancient
    yea, but if you have a RESPONSIBLE provider the shared Model is not that bad
    if you get too many people in one hub all the ISP has to do is "add a channel"
    Basically when you use cable modem your "watching a tv Channel" say "channel 1"
    ok so channel 1 can support 1,000 people, but there are 1500 signed up in your network area, so they create channel 2
    so now channel 1 has 750, and channel 2 has 750
    infact I know a guy that has a dual channel cable connection, get 3mb/s download ;)
  9. Civic96
    Civic96 Full Member
    Im sad!
    I can only do 63 kb/s! :(
    Its cheaper though lol
  10. deyton
    deyton Full Member
    How much do you guys pay? I got 1 mbit dsl for 35 bucks canadian monthly.
  11. The_Ancient
    what service do you have, if your not getting the Speed they claim, contact them...
    There is probally something not configured right....
    63kb is unacceptably. that is dialup speed, I dont care how much cheaper (which is probally is not that much cheaper)
    the average cost of Cable is $35/mo with TV Cable Service and $45 w/o Tv Service
  12. Civic96
    Civic96 Full Member
    Cable costs 48/month and DSL is 35/month.
    The modem dls about 10x faster than dialup.
    64Kb/s.......Mike, I think you misunderstood me
  13. The_Ancient
    Is that your "test" speed or what your transfering off of like on a P2P program?
    if you going by your download speed off a p2p prorgam that is a bad way to judge speed
    if that is your TEST speed, it SUCKS
    mine is 327.9 KB/sec or 2686 kbps
    and 10x faster than 56K is 560kbs or 70 KB/s :p
    I did miss the "K" and read it as "k" (who ever came up with those two was a moron I tell you)
    but stell. unless your paying for a 512 line, your still getting the Shaft, the common line is a 768 wich is 96KB/s
  14. Civic96
    Civic96 Full Member
    I think ill call these guys to clear things up.......
