I have a sony cd unit with common rca out jacks and then the high side(out) harness as well.I am ruuning these to a 600/4-channel amp.Both of which are Sony.No cross as of this time-maybe later but----?I have a set of kicker 6x8s in the front and quadaxles in the rear.Topped off with 2 10in subs in closed box located part rear seat/part trunk in my 2001 mustang.I have only 1 sub running due to blown voice in its twin.My deck has front/rear outs on low side.My amp has the same for ins.Any suggestions on running RCAs and high side outs from deck to amp?Can I use both to amp or will they cancel each othr out?My sub control is thru the deck menu and is supplied thru my rear out RCA jacks.I have no designated sub-out RCA location,but rear rca out is sufficient.As it is I have straight out of deck (high side) to front 6x8s and one rca patch to amp for subs.I know there is another way to route or wire ths system and am open for any and all suggestions please.
Hmmmmmmmm..........so the amp is hooked up to your sub,and the radio is running the front and rear speakers? so your question is how should you rewire your setup? you can run another set of rca's to the amp's front in, and run the rear out to the sub like you have it,and use the radio to power the rear speakers. does the sub have any kind of crossover?
