http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350356021228&ssPageName=STRK:MEWAX:IT (lanzar)^it has the most power for the same price as the others http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350395163851&ssPageName=STRK:MEWAX:IT (power acuostik)^that one is just the right amount for 2 kicker 12 l5's (same price) http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350395163851&ssPageName=STRK:MEWAX:IT (boss)and this one has more than i need also but thats fine, and all have a bass knob. witch should i get? thanks
None of those amps are what you want They might be in your price range but there not doing anywhere near the power the rated look at things like this when you buy a amp rms wattage at the impedance desired.Next most 1500 watt amps will have 4 40 amp fuses the reason is Because 1500/12= 125 amps this is the amount of current the amp pulls any fuse size below this will blow.Are your subs dual 4 or dual 2 If there dual 2 you need a two ohm stable 1500 watt amp if there there dual 4 you need a 1 ohm stable 1500 watt amp.If I had l7s and they were dual 4s and I was on a budget I would get a power bass 1500.1 if I had dual 2s your very limited on the amps that will produce 1500 watts at 2 ohms the only one that comes to mind is a kicker zx 1500 which is pricey.But in the end remember you pay for what you get those amps that your looking at will probably be a mistake and they'll fail then you will have to buy another so why not just spend the money the first time.
never mind you need 1200 rms But the amps I recommended are still good for what You need I thought it said l7s not l5s
I have an older PA that I'm pretty happy with.The Lanzar,I'd stay away from that.The Opti line is ok from Lanzar,but that's about it.I would pass on the Boss.Did you notice that the PA is a refurb?What ohm load are you trying to achieve?This is a decent amp: http://www.woofersetc.com/p7749/DTR...noblock-1400-Watt-ClassD-Series-Amplifier.htm
Cause im poor and im buying another l5 (i only have one as of now but im wanting two. and there for im having to buy both amp and sub witch is pushing me close to $300 as it is.
o and there dvc 2ohm and looking for 2ohm load. 0.5 would be nice but not many amps like that ideal lol. i was leaning twords the pa. there are a few good reviews on them
I had this same conversation about that amp your looking at 6 monthes ago my buddy has two kicker cvx twelves in a audi he bought the pa 1500 the amp broke two weeks after he bought it he had to pay to send it to episons pa and they sent it back and he sold it on craigslist. He bought a hifonics brutus bxi2008 it still works he's happy even though I'm not a hifonics fan.
http://cgi.ebay.com/POWER-ACOUSTIK-BAMF-4000-1D-4000W-MONO-Amplifier-Amp-/390259073065?pt=Car_Amplifiers&hash=item5add40e029 What about this one? even if it is over rated it will give enuff at 2ohms to power some l5s (and yes i know its a refrb)
o. well im out of cheap options... i need 1200 watts at 2 ohm load and my budget cant go over 200 (That ss you lead me to wasnt enuff i dont think)
i know a kid with the 5500 model. it works just fine for him. i was told a long time ago." buy the best you can afford". if thats what you can afford then so be it. even after impedance rise and voltage issues ( make sure you can supply the amp with sufficient current) you shouls still have more than enough power for your subs. BUT.... do you have your wiring in order? big amps need current. do you have a good batt under the hood? you may need another batt in the rear close to the amp. do you have a wiring large enough for a large amp like that?
BMW has 140 amp alt with good hefty wire and batt is in the trunk less than 3-4 feet of 0 ~ 4 (probly 0 g wire gauge) wire should get me preaty close shouldnt it? i think at idle the alt puts out 14 volts. not sure... (dont no much about the alts on vehiculars lol.)
well the batt in the trunk helps you to keep your power and ground runs short. have you done the Big 3? maybe another run of power from the alt to the batt can help if you have voltage issues after installing the amp. you may be able to wir in another batt with no problems. i have a stock 105 amp alt in my truck and 2 kinetik batts in the back. so, 3 batts on one small alt. zero voltage issues. it's over kill i know, but it don't hurt to have a lil extra amperage when needed.
do you go through alot of bats? if so would you need bigger / 2 alts to keep from draining them? The reason i ask is because my batts run from $90 -120. Thats my last ?? i hope lol and thanks
no. i do not go thru lots of batts. i don't listen to my system at full blast long enough to discharge them. if you were here in tampa,Fl i could show you this batt place that sells C&D batts dirt cheap. a lot of my teammates get their batts from there. 40 to 70 each for 134 ah batts.
