help with 4 x subwoofer box
Discussion in 'Subwoofer Box and Custom Fabrication' started by tallstahl31, Jan 5, 2012.
  1. tallstahl31
    tallstahl31 New Member
    hey I'm new to this forum but I'm not new to car audio.
    I've decided to challenge myself by making a 4 subwoofer box to put in the back of my 93 cavalier. now on to my question...
    When i make this box should I put a divider between the two sets of subs and have 2 seperate ports or should I make one big port and keep all 4 subs undivided?
  2. kcox669live
    kcox669live Full Member
    How many amps are you using and how will you be wiring subs to them?
  3. deepbass
    deepbass Full Member
    basicly sepretae any sub that has its own amp. so if your doing 2 subs per amp, you would want two chambers, both of the 2 subs would share air.
    only because any amp, even the same model set to the same levels will play different,
  4. tallstahl31
    ok, thank you very much.
