Hi all i have Vtrek Conccept XT 124 12" sub woofer. What i want from you guys is to help me by telling the exact dimension for tuned enclosure for both vented & sealed. Thanks
Or you could learn to do it yourself. But seriously this Vtrek Conccept XT 124 12" sub woofer is not telling me anything about the woofer. How about a link to the woofer specifications. That would be helpful. If you wanna do this yourself download WinISD , input your woofer specs and it can do alot of the design work for you.
Just a little bit more please, that link is not helpful at all. I need the woofer specifications. It should have come with the woofer. The specs for speakers are called Thiele/ Small Parameters. Those specs are also listed on the manufacturers website (which I can't find). So who makes that woofer.
this is what i found. Features Specifications: Description: XT-124 is a 12" & Dual Voice coil subwoofer, with Aluminum cone, High density foam edge, Nickel-plated screw terminal, and Strontium magnet. Specification:1). Max power: 500W2). RMS: 250W3). Sensitivity: 86+/-2dB4). Frequency response: 30-1.5kHz5). Impedance: 2/8ohm6). V.C diameter: 65mm7). Magnet: 49.7oz8). Vas: 48.8L9). Qts: 0.46
